One or two of you have been kind enough to help me on my previous thread, which concerned how to remove tiles intact from an old, crumbling shower cubicle etc. As I’m retired now, I’m lucky enough to have lots of time on my hands, and also have another shower, so can take a loooong time doing things, which of course wouldn't be economical for a builder or plumber.
So I’m working very slowly, asking lots of questions, doing as much as I can before getting a professional in. I’ve managed to remove the existing tiles – which I want to preserve – mostly intact, and am busy soaking them for days, then hacking the adhesive off the back to re-use them (I’m doing this because the entire en-suite is tiled with the same obsolete tiles, and I don’t want to do the whole place).
I’ve put new studding in, installed backer board etc, and am now ready to get a new shower tray in (the old one was made of something like mortar, and was cracked and leaking). So here’s my problem:
The original tray was fitted flush to the floor (in 1994) – as you can see, the mortar has been chased out to do this. What would you do now to replace it – go down the same road, or have a raised tray, to allow future access if necessary?
My builder cousin (who’s in England, so can’t do this for me) says he’d have a raised tray every time, but would build a wooden frame rather than use those little riser kits. What do you think?
If I stick with a flush tray, presumably there’s some kind of 2-part drain which lets you install the bottom bit, then just slide the top section, sealed to the tray, down into it? Otherwise can’t see how you’d fit it, when there’s no access underneath…
Hope somebody’s still awake… thanks
PS standard 760 x 760 tray
