Hi.
I have an Armitage Shanks Toilet Cistern 17501-2.
It was leaking from where it is joined to the Syphon (Armitage Shanks syphon).
Called a 'Plumber'. He unscrewed the nut. Pulled it down, and used PTFE tape. £160 for about 20 minutes work. Its leaking again.
I can do it, but I want to avoid removing the cistern. So, I consider two other choices.
1. Unscrew the nut, clean the area, and use Plumber's Mait, screw up the nut.
2. Cut off the existing rigid pipe and fit a flexible flush pipe. Only point I concerned about is getting the correct diameter.
Any ideas, please?. Thank you.
