Flush Pipe leaking
25 Jul 2014
Hi.
I have an Armitage Shanks Toilet Cistern 17501-2.
It was leaking from where it is joined to the Syphon (Armitage Shanks syphon).
Called a 'Plumber'. He unscrewed the nut. Pulled it down, and used PTFE tape. £160 for about 20 minutes work. Its leaking again.
I can do it, but I want to avoid removing the cistern. So, I consider two other choices.
1. Unscrew the nut, clean the area, and use Plumber's Mait, screw up the nut.
2. Cut off the existing rigid pipe and fit a flexible flush pipe. Only point I concerned about is getting the correct diameter.
Any ideas, please?. Thank you.
If it's a standard low level and it's leaking at the nut where the flush pipe fits into the syphon then that's usually just a 50p conical seal that needs looked at.
Thank you all. He is indeed a rip off merchant. I could have done it myself, just remove the cistern. But I was quite busy elsewhere.
Did it myself. Wanted more money, so with all the evidence, I am going to try and get him some real nice publicity. If the newspapers will accept it.
