Right... I've spent most of today, draining, flushing (repeat twice) our CH system and also removed and hose-flushed three problem rads (they're all cold, basically). I've also added Fernox F3 and will leave it to circulate now for a couple of days, as per the instructions.
However, the three rads that I flushed remain resolutely cold, despite having removed rather a lot of black sludge/oxide from the hose-out. Indeed, the rads themselves were allowing clear water to flow free before I put them back on the walls, so I'm pretty sure the rads themselves are now fine. So I would expect at least *some* warmth in them. All other rads are now wonderfully hot.
As a result, I fear that the pipework between the troublesome three must be blocked - and I'm doubtful whether Fernox F3 will be able to penetrate. For reference, the three rads are all in sequence (well, so far as I can tell) and are all on the ground floor. The pipework between the rads is small bore (half-inch/12.5mm).
So, where do I go from here? Is powerflushng the way forward? Or (forgive my naivety) is there some way to physically brush out the pipes, using the pro equivalent of a pipe cleaner? Or does anyone have any other ideas/suggestions?
Note, too, that the boiler seems to overheat and lock-out after about 30 mins. My theory is that this is because this is the time it takes to heat the first 11 rads (the 3 troublesome ones are at the end of the sequence) before the backed-up water boils in the pipes (I can literally hear that before the boiler locks out). Or is this a bonkers theory?
Of the three rads, one has a TRV that seems to be functioning (ie, the pin moves under resistance, as I would expect) while the other two are simple manual valves. I can feel the heat-feed pipe is hot into the first rad but cold on the exit (and then on to the remaining two).
All advice appreciated, as ever.
Harry.
Harry.
