- Joined
- 26 Feb 2020
- Messages
- 21
- Reaction score
- 0
- Country
Hello. Could anyone tell me whether a plumber who recently flushed all of my central heating radiators when installing a new Worcester bosch greenstar cdi combi did the correct procedure.
1. He turned off the boiler ( to avoid over pressurisation).
2. He closed the Central Heating flow and CH return valves. Attached a hose to the drain tap on the combi and opened it.
3. Shut all TRV’s on every radiator.
4. Then opened the filling loop fully to get mains pressure.
5. Then opened each TRV individually and flushed the radiator dirt and magnetic particles down the sink.
6. Flushing the radiator until the water went clear. Closed the TRV and went on to the next one. Once the flushing was done did the reverse and closed the TRV then shut off the filling loop and drain tap. Opened up all the TRV’s and opened the CH flow/return. Switched the boiler on and then filled the Greenstar system filter with corrosion inhibitor.
The question is can someone confirm that this method of flushing above is correct and done in the right way. Is there anything i have missed.
Thank you for your help.
