ford fiesta mk3 sunroof
24 Nov 2009
South Tyneside
hi, guys, ive just joined today. :o hoping for a bit info,ive just bought a fiesta mk3 on a g reg,& the factory fitted sun roof leaks bad. :roll: the rain channel fills up, then overflows in to the car :shock: the seals look ok. there are 2 drain holes at the front ,which i am told are connected to tubes , which run down inside the door posts.where do these tubes exit? somewhere near the front wheels? as im told they may be blocked. can anyone help ? :P thanks .
they either exit by the bottom of the windscreen or under the wheel arches.
try gently poking some curtain wire down the pipes with a bit of hot water.
