Ford Focus 2000 1.6 petrol central locking fault
12 May 2008
Lancashire
Can anyone help me please. My car has been posessed! the central locking is having a funny turn, all was fine until one night i went to lock it with the key fob and it clicked but didnt flash the hazards. i tried to sit in the car and when i pressed the locks it opened itself back up. i now have to sit in the drivers side hold the lock and rear lock so they lock then lock the rear passenger and climb through the passenger side and lock it with a key! ive used a snap-on ecu scanner but all i get is earth fault, i wondered if this fuse 63 would cure it or if anyone has had this BIZZARE problem? Thankyou :roll:
I have seen similar on a 2 dr KA where if you locked one of the doors it would immediately re open itself again. If I pressed both simultaneously then it would lock. This particular one was traced to a broken wire in the door plug where it connects to the car body.
If you operate the central locking, can you see the handles on all the doors move inside the car?
