Hi
We recently installed our 110mm underground plastic foul drainage pipe work. We used continuous lengths of pipe where we could bedded on 10mm pea gravel.
Where the pipe changed direction we used sweeping bends and installed and inspection chamber at the same time.
At the head of the longest run there is a bath, shower, whb and WC.
The run measures approximately 38 metres from this bathroom to the main sewer.
It has come to my attention that on the advice of the local BCO a graident of 1:100 was used, even though we had read that it should be 1:80 minimum with a WC.
As I understand it the height of the main sewer was partly to blame for this reduced gradient.
We have yet to use the WC so I am not sure if we are going to have problems.
A lot of care was taken when the pipe work was installed to ensure that the runs were as smooth and straight as possible.
Based on this info and the 1:100 gradient can anyone tell if we are going to have problems with blockages when we move in ?
Cheers
Cheers
