Foundations lower on one side
26 Jan 2020
Hi all, happy Easter!
I am embarking on a sort of self-build extension. I've dug the footings and had them filled with concrete but the surface isn't quite level - one corner is about 90mm lower than the other.
My builder had suggested I put some shuttering around and fill with more concrete to level it out.
Is this going to be ok? Is there anything further I should do to strengthen it or bond it to the existing concrete?
Thank you
Thank you
Shuttering, are your foundations above ground level?
You could drill holes to the poured footings and set in some short lengths of rebar using resin fixings which will help bond the top up pour to the rest of it. Make sure you allow enough cover over the rebar for a decent thickness of concrete.
Thank you
I'd be more inclined to deal with the discrepancy with masonry.
90mm! :eek:
Have you asked your BCO ?
I haven't spoken to the bco about this yet, no. Do you think it's something they would advise on?
It's over a span of 8m so it's not really that noticeable until you actually get a level on it.
I wondered why not masonry but I'm just going on the suggestion of the builder.
Thanks for all your advice so far.
He's not a builder.
He should sort out and mark the DPC level and guage down from that at each corner.
He should then work out the size step required and where it should go.
Do not tell the inspector.
sounds like a pig in the brickwork coming.....
trying to add to the foundation just adds a weakness in my opinion -its ok at 90 mm but what happens when you get below 30mm, the aggregate will be bigger than the the thickness.
from about 9 minutes in -a good explanation of how to deal with it
