Foundations
19 Aug 2013
Essex
So I'm building a porch and have decided that I want a wooden structure, possibly sip.. Question is can I use concrete footings rather than trench foundations?
I think you would need to use strip foundation as the sip panels or studs will need supporting the full length of the panel not at single points causing point loads. Do you have plans for the job easist option might be to hire a mini digger, or get a bricky to do the base.
