    Dismiss Notice
Franke Moselle Tap Leaking
Discussion in 'Plumbing and Central Heating' started by bobloes, 9 Sep 2020.
  1. bobloes
    bobloes
    11 Feb 2010
    61
    Thanks Received:
    Dorset
    Country:
    Hi All,
    I have a Franke Moselle Tap which I fitted in 2008 as part of my kitchen refurb. I noticed that it had developed a leak at the point where the spout joins the body of the tap. I ordered a washer kit but I have been unable to pull the spout out of the body. I can get it to the point where I can see the second washer but no further. Is there something other than brute force required? As far as I can see there are no grub screws or the like.
    Thanks. Bob
  2. denso13
    denso13
    22 Jan 2007
    4,822
    Thanks Received:
    1,048
    Country:
  3. Sponsored Links
  4. bobloes
    bobloes
    11 Feb 2010
    61
    Thanks Received:
    Dorset
    Country:
    Yes that is the first thing to unscrew otherwise you cannot see even the nylon circlip.
  5. muggles
    muggles
    28 Oct 2005
    12,928
    Thanks Received:
    2,906
    Daventry
    Country:
    Get some penetrating spray lube and dose it up well, then it should pull out. Good quality taps, I fit them all the time
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
