I'm fitting a Franke Eiger kitchen mixer tap and the pack of bits contains two rubber washers. One is a bevelled washer which clearly fits under the tap. The other washer is an O ring a little bigger than the tap hole If you use the triangular plastic support piece underneath and the C metal washer, I don't see that you need the rubber O ring. Is this right ? There is no recess under the tap to take this O ring.
I assume the fitting kit is multi-purpose so the rubber O ring may fit another tap. Any views, experience ?
BTW, I agree with other posters that the Franke instructions are rubbish.
