Hi, new here. I've just used the SEARCH and learned everything that I could find on pipe freezing. I've learned that it is advisable to freeze the pipe about 1m away from where you're going to be doing the work.
Now, I'm wanting to fit a towel warmer in the bathroom, which requires in-line valves. However, the (vertical) rad tails are about 6" long, and the pipework below the floor is pretty much inaccessable due to a chipboard floor that goes under the wall to the adjoining room.
So the question. How feasable is it to freeze the tails, bearing in mind that I would have to cut the freezing jacket to size? Or am I asking for a whole world of hurt? It just seems a tad excessive to drain down the whole system for just one radiator.
Cheers.
Cheers.
