Freshly Dug Ground Settle Before Fencing?
18 Apr 2007
Cambridgeshire
Just removed 2 fairly large tree stumps and had to dig around an area of about 3.5m x 2m up to around 50cm down. Now they've gone I'd like to redo the fence and need to put 2 x 8ft concrete fencing posts in at the edge of the area I've just dug over. Is there anything I can do to speed up the settling of the area? Based on that, how long would you recommend I leave it before digging post holes (60cm depth) ?
Thanks!
Anyone care to hazard a guess here?
Otherwise I'll leave it a month or so and have a go. Will report back if posts fall flat in the first bit of wind we get!
Fill it with earth and water the area, (give it a good soaking) you should see the earth sink, then refill until height required.
Do this several times until no more sinkage.
Andy
Thanks!
You need to get a footing into virgin untouched soil. If you set your posts into a 50cmx50cmx100cm deep cube of concrete they are unlikely to shift.
If you are using 6ft panels then you will also need a 6'' gravel board.
Thus making the post depth 18'' into the ground.(450mm)
The above goes for concrete or timber posts.
Andy
