- Joined
- 20 Jul 2025
- Messages
- 23
- Reaction score
- 0
- Country
Hi all
I'm having compression issues with my front door - big draft, bits of water getting in the track. You can feel it isn't tight enough when you shut it.
Keeps - I've tried adjusting all of them (there's three) in each direction, but no luck. Managed to make it worse, then reverted, but neither direction seems to make it as tight as it should be (currently left them in the middle). I believe the closer in the direction of the house - the tighter it should be? That doesn't seem to be happening with mine, though. That makes me think it may be the cams...
Cams - it's an XL Crimebeater multi-lock and it has seven of the square shaped holes. I've ordered a square allen set, but I'm not sure which of these needs to be adjusted - any ideas? I'm led to believe this is likely to be the solution - I just want to make sure I'm doing the right thing (and I assume clockwise, when I do identify the right one/s?) Pictures of all of these attached as well.
Thanks!
Thanks!
