Hi guys
I have an Ideal Mexico boiler situated in the conservatory, it has frost stat, room stat and RWB2 controller. Pump is on the 1st floor next to emersion cylinder, hot water can be gas or electric.
A new pump was fitted around 2 months ago.
System started to blow fuses a few weeks back an electrician friend checked it over quickly and could find nothing obvious.
I wired in a new 3 port valve tried it fuse blew straight away.
left it for a week before i killed it!! took out new 3port wiring and wired in the old valve ( i didnt actually remove the valve)
Fired up all ok for about an hour and half then blew!
Took out controller and bypassed that with 2 links last night, worked for an hour then blew!
changed fuse today and again worked for around 50 mins then blew!!
no obvious leaks anywhere near electrics. everything checked except the tank stat.
Any ideas
Driving me nuts
Any ideas
Driving me nuts
