fuse for bathroom extractor fan
17 Jan 2004
I want to add a switched FCU to an existing installation of a bathroom extractor fan - I've searched through other postings here for the relevant diagrams.
I'm planning to replace the existing pull-cord light switch with a DP switch as advised here.
Problem is, I want to replace the current unfused isolator outside the bathroom door with the switched FCU - but the current setup is just switching the permanent live. Neutral and earth are connected via a JB in the loft.
So is it okay to go ahead and replace the existing isolator switch with the SFCU? Or is there a better way to do it?
the isolator is there to isloate all poles (live, neutral & switched live) an fcu will not do that that.
why do you want an fcu anyway?
I've read various bits of advice (on this forum and elsewhere) that ideally a bathroom extractor should be fused down to 3A - to comply with manufacturer's recommendations, if nothing else.
Just trying to make sure I've got everything covered while I'm tidying up the (previous owner's) installation ...
Yes it will...
I think breezer meant that it won't work in the way that I was proposing to do it (just switching the live) - in which case it's a switch, not an isolator.
I'll follow your diagram to do it properly - thanks.
