Indeed, as I wrote ....In the case of medical equipment, you have to consider it's manner of use. likeky to be used in conditions where someone is more susceptible to shocks than normal.
However, having said that, I don't think that any measures involving fuses will be of much benefit to people at increased risk from electric shocks.Medical equipment is, of course, a fairly special case, in which one often sees safety-related measures which go beyond what one would see in other equipment.
Are you still talking about medical equipment, or generally? If the former, then this discussion has gone even further off-topic relative to the OP, which was about neutral (only) fusing. If the latter, are you suggesting that all electrical equipment should have internal fusing (to provide fault protection)?So it makes perfect sense to provide local fusing, and since in many markets (as already said) polarity is flexible, that means DP fusing. Internal to equipment I see little problems with that - anyone working inside it should either have unplugged it or know how to work safely. That's little different to equipment with no internal fusing.
Kind Regards, John
