G2-12 panel. Add additional keypad. Wireless possible?
M
mwjburton
We had a Honeywell G2-12 panel installed a few years ago (8 PIR, 4 door contacts, 2 MK7 keypads). We would very much like to add an additional keypad so we can arm and disarm the system from the 1st floor / outside master bed. Currently the other keypads are on the ground and lower ground floor next to entry points.
Assuming there is not a 2 keypad limit (in which case we may need to look at switching the panel to something with more capacity)...
...we would like to add a wireless keypad (avoids messing up recently decorated walls). From what I have read in various posts, I'm still unsure if this is even an option? Please could someone clarify whether this could be an option for this system? I'm fairly sure its not an option with Honeywell products and the G2, but perhaps it is with 3rd party product additions?
If wireless is not an option, could we 'T' off an existing PIR point and use a spare core to run a wire down to another MK7 keypad?
Lastly, I understand there is an option to use a wireless keyfob with a receiver. To me this doesn't feel a hugely secure option having a button which disarms the system with a keypress and no code. Perhaps I'm not appreciating the benefits though?
Anyway, would really appreciate some advice. I will ultimately be using an alarm installer to do the work, but I'm very keen to fully understand our options before I start getting a quote.
Many thanks for your time,
Mark
There's no wireless keypad, only phone apps. The phone apps require that your panel is on Ethernet. The panel can support 4 physical keypads or three physical and one virtual when the LCE Ethernet module is fitted.
It depends on the number of cores you have available to add the keypad. It's not normal practice to mix zones and bus devices, but there shouldn't be any problems as the bus signals and zone signals are pretty resilient to noise. You need at least 5 cores to hang a keypad and a sensor from the one cable.
The wireless keyfob is an option, but will require that you add an RF portal to turn your panel into a hybrid system. The fob is two way and uses a rolling code.
https://www.security.honeywell.com/uk/documents/HSG-KEYFOBS-EN-DS-E.pdf
Many thanks GalaxyGuy, this is extremely helpful. We do have an ethernet port next to our alarm so I could potentially connect it to the network. Do you have any further info on the products we would use to enable this. I assume we need an ethernet card for the panel and an app. This could actually work well for us.
Mark
I don't really want to plug my products, as I'm really only here to give neutral advice. Google for LCE module for the Galaxy, as this is the only module that can offer remote keypad on the G2 panel.
Thanks very much for your advice. That is exactly what I'm looking for!! Perfect
We have the LCE ethernet module mentioned above, and use the selfmon service. It works flawlessly and I can highly recommend it.
Fantastic, just need to get my alarm maintenance firm to quote me for install now!
