Galaxy 3-48 relais
12 Nov 2014
Galaxy 3-48
I don’t have the engineer code for the system. Nobody knows it and the installer is no more available.
Due to this fact, I like to attach (hardwired), a slave system and wonder if I can use the relay NC/NO relay on RIO 1. I need to arm the slave system according the galaxy.
Any other idea is appreciated as well. Thanks.
As per my PM, you really need to use the engineer code to change output 1002 type from 'strobe' to 'set'. You can then use the relay to set the secondary system when the primary Galaxy system is set.
