Galaxy 16+ manual
12 Sep 2007
Bristol
Can anyone out there provide me with a installation manual for my Galaxy 16+ system. I have the engineers codes & manager code & the software but no manuals.
Cheers peeps
Breezer,
Well my Dad had it taken out of his place when they moved. I now want to install it in my house and although im a electronics engineer by trade i think im gonna need the installation manual and engineers manual to get it all connected up and programed.
Cheers
I have one in the but have a policy of not handing them out, i am prepared to answer any questions you may have, if your competent you shouldn't have a problem with the cableing, you have the codes and the programming on galaxy's are quite straight forward!
daweorama, wire it up then connect it. it is labled
enter codes to silence than ask how to programme it.
do bear in mind it uses EOL and shunt resisitors, both 1k
not sure? see the sticky i did years ago (sticky in uk electrics, theis frrum doesnt have a stiky on stuff)
Ok i see well hopefully il get on ok. I cant moan much i suppose as I have the same policy when it comes to my stuff. Not sure to start with where and when to use the resistors.
Also any chance of the connection drawing? I think i should be ok with the programming. "Hopefully"
dont need a drawing, have a look at the pcb , its labled.
resistor drawing is in the electrics forum sticky
Breezer cheers for the help so far.
Could you post me the url for your sticky on uk electrics? sorry if that sounds lazy.
***removed***
Also if anyone else out there has the mauals they would be much appreciated. To sum up below is what my system comprises of.
1X GALAXY 16+ WITH ON-BOARD COMMS END-STATION
1X GALAXY MK7 ADT RESIDENTIAL LCD REMOTE KEYPAD
4X HONEYWELL DT7550A-UK DUALTEC PIR DETECTORS WITH ANTI-MASK
1X HONEYWELL FG1625TAS GLASSBREAK DETECTOR
1X CQR P.A. BUTTON
2X WHITE SURFACE DOOR CONTACTS
1X ARITECH AS270 INTERNAL SOUNDER
1X ELMDENE VERTEC 500 HIGH SECURITY EXTERNAL SAB SOUNDER & STROBE C/W NI-CAD BATTERY BACK-UP
1X PACK OF RESISTORS
1X UDL (UPLOAD/DOWNLOAD SOFTWARE)
as i said, wire it up, then ask.
oh, doesnt need an internal sounder, does need an internal speaker though (16 ohm)
