Galaxy code number of digits
11 Jan 2020
Quick one folks...
Galaxy flex 50... codes seem to need to be 5 digits long... can I change this to 4?
Perfect, thank you!
Don't supposed you mulled over my speaker volume issue any further did you???
Sorry, I need to try this on a test panel in the office. Just not had the time lately.
No worries mate... can you confirm my understanding is correct:
The L/S circuit is based on 16 ohm?
1 x 16 ohm L/S gives 16 ohm, so should work with volume control as is?
2 x 16 ohm L/S in parallel gives 8 ohm?
2 x 16 ohm L/S in parallel would require resistors to give a resistance of 32 ohm on each L/S circuit in order for the volume control to work?
Just want to make sure that I'm not missing something.
