    Dismiss Notice
Galaxy dimension
Discussion in 'Alarms, CCTV & Telephones' started by dya, 9 Nov 2019.
  1. dya
    dya
    2 Jan 2017
    51
    Thanks Received:
    Country:
    Romania
    Hello guys
    I have a strange problem with a GD264 panel.
    So, when I try to set the system, a zone that is closed, change state and opens, and don't let me set the systems. I verified during the timed set if something open the zone, but nothing found.
    The zone is a motion detection, defined as intruder. Before seting the group is ready, showing R. As soon as the timed set count down the zone opens without reason.
    To set the system I have to omit the zone.
    Any ideas?
  2. scott1980
    scott1980
    3 Mar 2006
    485
    Thanks Received:
    90
    Manchester
    Country:
    Have you tried bypassing the zone with a 1K resistor to see if the problem persists? Can you move the sensor to a different zone to prove the sensor/wiring? Sounds like it might be a firmware issue.
  3. Sponsored Links
  4. dya
    dya
    2 Jan 2017
    51
    Thanks Received:
    Country:
    Romania
    Hello, thanks for the answer
    Yesterday I finished late at night, I didn't try anything.
    I will see that monday .
    The firmware is 7.02. I think I can do a firmware upgrade if necesary.
    Thanks a lot men.
  5. dya
    dya
    2 Jan 2017
    51
    Thanks Received:
    Country:
    Romania
    Hello again
    Another question about gd
    Can I link a zone with an output, if the output is not alocated to a group?
    For the moment I cannot tested by myself because I can't install galaxy RSS. (actualy when I start commserv the frontshell don't come up)
    Thanks.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
