I've upgraded from an old Galaxy 16+ panel to a Flex 50, and have a few questions that I can't find answers to in the manual..Hope somebody can help?
1. Following the unset procedure, the panel displays 0=OMIT ZONES, whereas I'd ideally like it to revert to the standard banner, rather than the programming)
I am wondering if this is to do with the level of user access linked with the code that I use to set / unset, and a code with a lower access level should be used.
2. Following the unset procedure (from full set), the horn sounds twice. Is there a way to defeat this?
3. Following the night set and unset procedure, the horn sounds twice. Is there a way to defeat this? (I'd like to use night set and unset when people may be sleeping)
4. When the alarm is part or fully set, the standard banner is displayed. I'd ideally like to set the banner to either say 'system armed' or to be blank. Is this possible?
5. The manual (ref 800-11184-01 rev A1) supplied with the panel (supplied on CD) does not match with the firmware (3.39) that was installed on the panel. An example is that the firmware includes a Night Set option that is not mentionned in the manual. Any ideas where I can find the correct manual?
Thanks,
Jon
Thanks,
Jon
