Hello
With the advice of the helpful guys on here I did plasterboard the ceiling and partition wall. And will get a plasterer to skim. I read that you should leave 5mm gaps between the plasterboard. Even though I was using small boards it was difficult to do the ceiling, and in some parts the gaps are bigger then 5mm, maybe more like 1cm. I've just bought some joint filler and tape, but it says on the filler that the gaps should not be bigger than 5mm. Next to the edge of the ceiling there are some gaps maybe 5cm wide.
I guess I should fill the larger gaps with bits of plasterboard, but what gap is acceptable? I imagine it will be difficult to screw small bits of plasterboard to the joists without it breaking up. I wondered if it would be ok just to push a thick mix of compound between the laths where there are gaps? (I've left the laths in place on the ceiling.)
Will the jointing compound stick to the laths between the gaps? ( One guy told me that plaster does not stick to wood.
Also should I apply PVA, diluted or not, before the jointing compound being as it will be in contact with the lath in some places?
Also I read that the screws should be recessed, this is fine for the wall, but when I screwed the screws into the ceiling, even flush to the surface of the plasterboard, the plasterboard started to break up and was not held securely. Therefore the screws are 1 mm or so proud of the surfce. Will this be a problem when the guy comes to skim? (I tried nails at first, but these went straight through the board). I've used screws at the recommended intervals, even a bit closer in parts.
Thank you for any help.
Amanda
Amanda
