Garage Build Which Blocks
4 Apr 2010
Flintshire
Well after being on here reading for ages i finally have a questin to ask:)
I am building a detached garage next month 4.8m x 8m, with a pitched roof. It will be a single skin construction and rendered. Ideally i would like it to keep as warm as possible, because i will probably use it as a workshop too. My brickie is my retired father inlaw so i want to keep the blocks as light as possible so he doesn't struggle, but they also need to be strong because i wasn't planning on having the inside plastered. What blocks and thickness would you recommend for strength, ease for laying and warmth?
Thanks in advance for any help
My garage has 9" blockwork to rear and right hand side [not visible from street] the front and left are 4 inch block with insulated cavity and brick face, you can have thin blocks but they don't go with your insulation requirements, can't have it both ways. :wink:
I would never alter a construction due to limitations of bricky worth paying someone if he is not up to the job.
Build it cavity construction then.
You can't have your cake and eat it.
If the blocks are 'on show' i would always suggest going for dense 7n concrete fellas. Heavy but durable and not particularly porous.
The problem with blocks with the greatest thermal resistance (aerated) is they are very porous. Lightweight, but soak up water like a sponge.
You could consider hollow 140mm fellas.
