Looking for some advice, im considering converting my integral garage to a play room with a utility room at one end.
Basically i have access from the Hallway into the garage where at one end is the Washer / Dryer etc and boiler, i want to segregate this area off from the rest of the garage, would a Medium density block wall be better and cheaper than a Stud Wall ? i have done many stud walls so can do this myself, but would need a builder to do the blocks, and would med density or high density be best ? i intend to hang a 42 tv on one side.
Secondlly i intend to have the garage door bricked up so far then a full (garage door width) window put in and a new opeing put in from the hall between 2 storage cupboards then joist the floor to bring it up to the level of the current floor which is also on joists with floorboards.
Can anyone see any problems with this ? as i see it i think i only need building regs not planning, any thoughts ?
Im pretty good with DIY and will probably only get the block work done by a pro, the electrics are all in place already so wont need to touch them.
Any advice would be appreciated.
