GARAGE CONVERSION......with a difference!
16 May 2006
Pembrokeshire
A bit of advice needed if possible please!
Hard to imagine , this, but here goes.......
A bungalow (early 70's) built into the side of a hill; double garage BELOW the floor. Similar to split level construction but all the accommodation on the first floor I suppose?!
I'm looking at the possibility of converting the garage into probably an en suite bedroom with access internally - obviously a staircase.
I know there will be building reg issues regarding things like insulation on the walls and floor, and lighting and ventilation etc etc, BUT could anyone give me any advice please on the basic requirements regarding means of escape? Will it be permissable for example to have the only actual exit as this new internal staircase, even if there is a good sized window available as a secondary m.o.e., or will an additional door to fresh air be required? :eek:
Many thanks!
If I understand correctly this new habitable room will be effectively in a basement and the exit will be via a stairwell and then through a door at ground floor level. If this is the case, assuming the layout is nothing unusual, a window providing (and conforming to) MOE requirements within the room should be sufficient.
hth
Many thanks!
Thanks for the reply.......this IS the situaution (as HotRod has interpreted) but there may be one big difference - we would ideally want the staircase OPEN at the top (no door) and any door on the 'basement' floor.......any probs with this??!
