Garage Floor and Dampness
L33
23 Dec 2014
Lancashire
Hello,
I am after some advice as I have just had my garage refurbished with a new roof, door, windows, etc as the plan is to turn it into a gym.
The floor is concrete and the walls being boarded inside.
However, there seems to be damp coming through the walls & the floor is quite damp with small pools of water of which is coming from the ground because there are no leaks in the roof.
I was told by our builder that you can purchase some kind of rubberised paint to use as a sealant.
Does anyone have any idea what this is called and where I can get it?
Thanks.
Lee.
N
Newboy
If you've got ground water rising and forming pools on the floor then none of the rubberised paints will solve it
L33
23 Dec 2014
Lancashire
I'm gonna try the rubberized paint first to see what kind of effect it has.
Which is the best one to use?
N
Newboy
none of them - they won't adhere to a floor as wet as you've described.
If you have water rising through the slab then the 'paint' will simply be forced off the slab surface
25 Feb 2005
As you have said, water is rising through the concrete floor, this means that the water has come from a place HIGHER then the floor, i.e. the garage has been cut into a hillside or such like. The best attempt I can think of, is to surround the garage with a french drain which drains into a sloping land drain away from the garage to encourage the water to go somewhere else.
Frank
