Garage Wall Replacement
I agree with most that you say. It boils down to whether moisture is wicking up the bricks from the ground or there is a higher water pressure in the wall causing it to flow out of the masonry (bricks or mortar) onto the garage floor. My understanding from the original post was the garage floor was being saturated to the point of being wet.
Personally, I have never experienced moisture wicking up the bricks and forming a “puddle” inside but have experienced very damp walls (much as you describe on your rendered plinth). Where bricks are made damp by capillary action it stays in the bricks and may cause the garage floor to become damp (and typically ruins any porous finishes inside a house) but will not “saturate” it to the point it looks wet. Not to be confused with moisture condensing on a cold wall – sorry to throw that one in.
The first stage is to solve the problem of the higher water pressure in the brick whether due to drips, rain, water transferring from the build up of muck outside or water ponding on the concrete outside (if the outside concrete is at similar level to inside). Avoiding drips from the gutter and any build up of muck can be easily tackled but rain / build up of water on the outside surface are more difficult to manage. Reducing the level of concrete outside will help but also need to ensure the area can freely drain such that standing water cannot build up and come in contact with the wall.
I would agree that you don’t want to do anything to prevent drying out or trapping moisture in the wall but unless the route cause of higher pore pressure in the masonry is solved the cause is lost. Ideally the outside needs to be lower than the inside and the addition of fillets may solve the issue but wont necessarily cure the problem. They are a way of displacing standing water and may be easier to add than breaking out concrete. Fillets (like concrete) are not materials that easily allow for the passage of water but of course they may fail in time. A barrier (need only be an inch or so) such as black jack or similar may help but I agree it should not extend to the DPC (if one installed) but should allow some unsealed surface for drying. Also need to bear in mind that if the wall gets saturated from rain and you add an external barrier that moisture (when saturated) will then come out on the inside ! (which is a relevant point you have made).
Its a balance of what steps to take and demonstrates how important it is to get building details right in the first place to avoid problems occurring in the future. I hope that Anderson365 has progressed with his remedial works and our thoughts may now be theoretical but may allow others to get a perspective of the issues for their own problems.
My last comment regarding your bricks / plinth I expect was down to porous bricks used in the post war building boom. Similar issue on a 1950’s house. Nowadays there are requirements for more durable bricks below ground level. The issue was probably the bond between the rendered plinth and brick had failed, either due to poor workmanship or frost action, and ideally should have been replaced. I suspect the rendered plinth acted as a sacrificial element providing protection to the wet bricks.
Thanks for all of the suggestions.
To clarify - water was pooling on the inside of the garage to the point that the kids could splash in the puddle. While it kept them amused I was a bit fed up.
I had only had four days to take the fence down carefully, do whatever work I could and get the fence back up as agreed.
Ended up digging out any excess dirt that I could access, surprised by the amount that came from a 6"x6" space). Bottom two courses of bricks are no longer below ground level.
There was no space for a proper land drain as the concrete support for the neighbours fence posts was in the way.
Sorted the pointing out on bottom few courses of bricks, chipping away any dodgy bits of the slab that would direct water back towards the wall and as a last resort I ran a length of DPC along the existing material and had it fall into a gutter I setup at ground level.
Made the best of what I could in the limited time available.
I know the pictures don't show much but they are there as my suggestion if anyone has similar issues with limited time & budget. Seems to have worked well enough over the last very wet weekend. Next onto the roof which is truly on its last legs with a hole appearing in the felt over the last week.
Great job for summarising what you did. Usually, the outcome is unknown and very useful for others that come across the post to appreciate the issues. Fingers crossed that the fix continues to work.
Going to see if I can drag this thread out for a bit longer.
Onto the roofing now, thankfully with all the rain most of the existing deck has turned to mush which I will use to mulch the garden flower beds. My plan was to strip off the existing roofing and lay an extra two courses of bricks to give the roof a better pitch (currently 1.5 degrees).
I will reuse the existing rafters to save cash unless someone on here suggests otherwise.
Pop on some OSB or ply wood decking from FB Marketplace on a dry day, cover with a sheet of DPM from screwfix until the EDPM is delivered and fit that on another rare sunny day. Was torn between this and box profile but this seems easier and quicker to fit.
This all sounds a bit too straightforward so something is bound to go wrong. Any one done similar in the past? happy to receive harsh criticism before I get started if it saves me pain down the line.
Preferable to use 18mm tongue & grouve OSB3 which should be waterproof. If not you will end up with the mush as your existing roof when (if) it gets damp / wet. This will span up to 600mm but you could use 15mm so long as you dont jump up & down on it and use a plank for access. The T&G should help minimise movement between boards and prolong the life of your top membrane. I'll leave others to comment on EPDM or GRP or was it poly carb twin wall.
. . . and I wouldnt use the old osb as mulch as I doubt the chemical cocktail will be good for the ground. Your local recycling centre should take it as timber.
oh dear, I hadn't thought of that. Half that turned to mush already has been spread and mixed in to the flowerbeds and the veg patch so it might be a bad year for veggies. Will let you know next spring if I live in a barren wasteland of my own making.
