I have a garage which has one strip light and one electrical socket. I want to have a proper set of lighting and sockets wired in. With a dedicated supply to the garage and a seperate circuit breaker/consumer unit. I have produced a plan which shows all the rings I require and where the sockets and switches should go. I want one lighting ring, one socket ring and then two dedicated higher amp rings for a table saw and dust collector. I want to save as much money as I can on this project, but obviously doing the work myself is out of the question. I wonder what the best things to do are to save money?
I want to install stud walls with plaster/peg board and I want the switches, circuit breakers etc mounted on the board, and the cable run behind. This is going to mean the electritian will have to come and run the cable, then I will have to attach the boards, and the electrictrian will come back and connect everything up. Is there any way round this? Would it cost me less if the cable was routed on the board in ducting? Surely that way I could put the walls up first and the electrictrian would only have to come once?
Is it cheaper for me to supply the wiring and sockets etc, or get them from the electrictian?
Sorry for the long post, I hope you have some ideas?
