I have built a garden cabin for use as an office/photo studio. Distance from the house is about 45 metres.
With heater, lights, computer, etc., all on at the same time, I estimate that highest current will be 20 amps.
I will get a qualified electrician to check out the wiring and do the final connection to the main consumer board to make it legal.
Questions:
1. Will 2.5 armoured cable from the house, buried in the ground, be heavy enough for the whole project.
2. Should I use a garage consumer unit (with earth leakage)?
I was advised by an electrician that new regulations state that there should be an additional earth rod and connection at the cabin.
There will only be two circuits - a plug circuit and lighting circuit.
3. Is it possible to put the consumer unit in a weather proof box outside the cabin and then to take the cabling outside to the lights and plugs? Ideally, I would like to take the cables along the back and one side of the cabin where they will not be seen.
Thanks for your help.
Questions:
