Hi folks, I’ve done quite a bit of research but can’t find the exact answer to the exact question I have; do I need a cavity in a 2 skin concrete block wall to satisfy k-rend requirements?
Background. I have had a 1.5m block retaining wall built and hope to k rend it (eventually after other building work complete). I need to build the inner skin next, and was wondering if I should fill the cavity with a strong sharp based mix and PVA, or leave it air gapped so as to have a dry facade? The back skin is block on edge with deadman blocks, good drainage at foundation level into a land drain, back filled top to bottom with 10&20mm limestone and has a couple of large concrete stantions. There is no damp proof or visqueen etc between the limestone and the block.
I’m confident the cavity would remain dry but I was thinking that filling it for a wedge of extra strength might not be a bad thing. I can’t find anything that specifically says a cavity is required for k-rend so what are people’s thoughts here? I guess another question is would a solid wall be more prone to cracking? (but as the fill would be PVA’d, would this help or hinder?)
Many thanks in advance, Phil.
