It will probably be either a 3/8" or a 1/2" tap washer.I guess I need to replace the washer, what type and size of washer would it normally be?
Hi
Replace the whole tap its a lot less bother.
You're right - taps certainly do cost about a fiver.
Do you advocate replacing the entire tap because it's cheap, or because it's quick, or both?yes garden taps do cost less than a fiver, whats your point?
And do you advocate not replacing the 20p washer because it's expensive, or slow, or both?both
I have a stock of 100 1/2" washers, worth about £20 and taking up very little space. Your equivalent stock of taps would cost you more than £430, and take up an entire crate of space.
Or do you drive to Screwfix every time you need a tap? Surely that makes a tap replacement very expensive and time-consuming?
And how much do you care about about the environmental cost of scrapping a serviceable tap?
Clearly.lol, i'm not doing the job
Not really - he knows that it's either 3/8" or 1/2".This is a householder we're talking about. say he goes off buys a washer, not sure what size, so good chance he could get that wrong
If he's intent on doing his own tap maintenance, then of course he should.maybe he should buy a tap reseating tool as well?
Your favourite supplier sells the tool for the "ridiculous" price of less than two taps:stop being ridiculous.
No it isn't - it costs 20 times as much as a washer.a new tap is cheap for the "diyer"
What are the exact terms and conditions of your guarantee?its easy for the "diyer" and is a guaranteed fix.
I agree, but since you're now gambling there's also a chance that the existing tap is serviceable and already compliant.There's also a reasonable chance by buying one c/w check valve he'll be bringing the installation up to regulation as well.
Can change a washer in under 30 seconds - without turning the water off and no mess! any pressure!
