Garden Wall uplighter
4 Jan 2009
Herefordshire
I'm after several external lights for a garden wall. (apparently)
I'm after a small uplighter affair to light up behind the plants :?
Would like them small, nice looking and cheap (as I want quite a few). :roll:
Having a look on ebay, most seam to be downlighters.
Any idea's suguestions ?
Turn them up the other way? :lol:
Check our Deluce Lighting, they have a good range of spots, uplighters, etc.
Use a down lighter facing down onto a small stainless steel mirror. That way the unit is less likely to be affected by rain. With the glass at the bottom the openable seal between glass to casing (needed to enable replacing blown lamps ) is less critical so a lower IP rating might be applicable and therefor cheaper lamps might be suitable.
In my experience (not from installing, I hasten to add, but from replacing!) 'cheap' and 'garden lights' are not a good combination as they won't be well made and will end up causing no end of problems due to water ingress.
Worth splashing out (no pun intended) on some quality lights
SB
