a.
It's obviously NOT a permanent connection but that is not the criterion.I'm now being told this represents a permanent connection to the house wiring and requires 'Part P' documentation.
How have you earthed the steel armour?
Yes.
I had two opinions on this - one said not to bother and the other said do it so I took what looked like the safer choice.
Unbelievable.Incidentally, 1.5mm armoured cable fits into a 13amp plug with no problems and the earth is taken off the stripped steel armour running into a ground spike at both ends.
To the last poster - why should I pay something like £150 (or employ the services of a professional electrician, which I suspect is what you are suggesting) to do what I've been doing without any problems for the past year?
It seems that the law encourages the bodge, which is running a simple extension lead to the shed, by putting any other option outside the reach of DiYers. That doesn't make sense.
I've reported the use of the word pr**k to the moderators
3. I can do what I did - put the wiring in myself (total cost for parts under £60) but because it might be deemed to be an 'installation' I then have to get it documented for Part P compliance at a cost of around £150.
