Hi I'm having to remove my kitchen cabinets to provide access to the floor/wall.
As part of this I need to remove the gas hob. I've turned the valve in the pipe run 90° and confirmed that there is no gas to the hob. Just for safety I bought some 15mm compression stop ends from screfix (#65021), however I've noticed on the Q&A where someone asked about use with gas that the answer is that they do not recommend using the fitting with gas.
Is this just arse-covering or is there a specific compression stop end that I need to use with gas pipes?
Many thanks
Many thanks
