Hi
I have had a heating and hot water system linked to a wood burner and gas boiler via a thermal store. The wood burner works fine, but the gas boiler fails to heat the thermal store adequately. The gas boiler heats water for 1 -2 minutes and then cuts out for a period of several minutes before heating the water again. This is does not heat the thermal store adequately via the 15 KW heat exchanger. The installer seems confused by the problems!
Any help would really be appreciated.
