gas central heating timer not working
8 Mar 2007
Hi can some one enlighten me my timer from which both the heating and hot water are controled seems to have stopped working its a danfoss electronic one with the lcd display i have preesed the reset button but nothing,its on a gravity system wether that means anything,what else should i try? thanks
Which model Danfoss?
Is the LCD display working, i.e you can read it and make changes?
Have you checked the fuses? The heating system should be connected via a fused spur or a 3 pin plug and socket.
i have tried the fuse which is next to the boiler,no signs of life the danfoss is with lcd screen which is dead theres nothing there so you cannot make changes its the basic one with buttons for heating on one side and water on other
the reset button is infront so i can press that but as i say no life so i have to change timer you all reckon
cheers bolton whats the best way of checking powers going in?
use a multimeter or some device that tells you power is going in. or get someone who knows what his doing before you do something unsafe
cheers bolton i got a multi meter which wires do i need to check .dont worry i never attempt anything if im not sure about it
have you taken the clock of the wall yet. at the back of the clock it will tell you what wires are what, for testing purpose you could make it work, find out by taking clock off
ok guys i have now replaced my programmer(dansoff fp 715 si)the programmer now comes on but the boiler does not fire up have noticed as soon as the programmer has been on a minute a fuse blows upstairs in airing cupboard here the programmer,thermostat.pump are all wired its a 2amp fuse,the boiler is a ideal icos he18 on the boiler there is the number 0 on display but the burner LED is off any ideas gentlemen
thanks for your time
hi bolton i have done a like for like i took off the fp715si and replaced with the same,bit baffled
