GAS FIRE
If it had a badge and it said 6.7kw and yea gas rated it and worked out to be 7.1kw what has caused this fire input to rise to 7.1kw is it the injector, pipesize, ventalation, ?????????[/quote]
Is that 6.7kw gross or net and have you gas rated to gross or to net.
For example 7.1kw gross is 6.4kw net.
Otherwise i'd agree that prob a worn injector
And remember, when checking working pressure, :P you will need other appliances working, i normally turn 3 burners on at the hob whilst calculating.
ItsOverFlo said:
And remember, when gas rating you will need other appliances working, i normally turn 3 burners on at the hob whilst calculating.
I think that's for working pressure at the meter not gas rating an individual appliance. If you had another appliance working you would have no idea of how much gas the appliance that you are checking is using.
Are you finding that there are a lot of overgassed appliances out there :roll:
:lol:
ItsOverFlo said:
I bet this chap works for reactfast & co ............. did is fast track course and here,s the result. OOOPS .. i just blown someone,s house up today.
And you are so much better BOB that you have to ask such a basic question..... take it that it was another lie the other week when i think you said you where a lecturer in the subject
I gotta come clean with you namsag i really am a airline pilot, i used to be an astronaut but i got a bit bored with it.
Can understand you giving the astonaut job up bob as there was never a good atmosphere in the work place.
