When I entered my house last night I smelt gas! So I called Transco immediately.
Engineer arrived, did a test in the meter and detected that the was a leak from my internal pipe. He then did changed the outlet connector to see if the leak was from their side but even then it was showing sign of leak from my side.
Anyhow, he then used a sniff in all of my gas appliance, from the gas cooker to gas fire there was to trace of gas leak.
But when he dose the test from the actual meter there is a sign of a leak some where and it is said to me its from my internal pipe. So their have left the gas disconnect and advised me to call COGI man to find out where the leak my be.
Phoned one COGI, he said in this situation you’d have to re-do all of the gas pipe.
Is this correct?
Any advise will be appreciated
Is this correct?
