Gas pipe through door step...
23 Jun 2006
Hampshire
I'm having my front door moved and as part of that work the gas meter is being moved too.
I believe the gas chap is going to join on to the existing pipe under the screed and then come out through the wall in a sleeve (im sure he said 32mm waste pipe for this) before clipping along the outside wall to the new meter location.
Below is a random pic I found on the web but basically my arrangement will be similar but the pipe will turn under the step and enter the house to the join under the screed.
I didn't discuss with the chap when he was here but will there be any problem with the gas pipe inside the step? Would it need sleeving? And would that sleeving need to join to the one that goes through the wall.
This is more about how i design the step than the gas side of world so i hope its not a problem to ask this gas type question here
I'm no gas man nor builder but that does not look like an ideal arrangement to me.
That step will have people walking on it, loads placed on it etc.
Methinks that it will eventually move downwards on the thicker copper pipe that its laying on and that could cause problems.
So for your installation I'd suggest that the pipe is deeper so nothing is lying on it like in the pic.
