I need to extend a gas pipe that comes out of the wall, the pipe is a black\brownish
Steel pipe, looks about, ¾ or 1” the pipe will need to tee of in 2 directions, to gas hob, and to boiler, on the the one to the hob needs to go under the ground, solid concrete floor. about 2 meters will need to be under the floor. I have dug the floor up.
I have had a couple of Cogri people round (yes looked at the card and flipped it) both say completely different things, one said he would run 15mm copper inside a plastic tube. The other guy said he would use a steel pipe, and cut it on site, bsp thread it, and connect it up with a compression fit to the existing pipe in the wall, and bayonet the other end, for the hob.
Copper sounds quite simple and good, what do you guys use, for this type of job.
What sounds the best to go for? The copper was much cheaper.
Darren
Darren
