Boiler drain valve (I mean central heating drain valve, below combi boiler) is helpfully facing the wall, there is a gas supply pipe 11cm above it. I don't know if I'm allowed to desolder and move the drain valve but I'd guess since it's not a part of the boiler yes?
The bigger question is, if I switch the gas off at the meter then run the boiler until it fails, can I be confident there is no gas left in the pipe which would explode? I'd not expect it would get too hot from the flame at that distance anyway, but I don't know about gas... so... from those that do?
