D
davebgas
Then whoever said that is wrong......i saw the thread as well.
"“gas fittings” means gas pipework, valves (other than emergency controls), regulators and meters, and fittings, apparatus and appliances designed for use by consumers of gas for heating, lighting, cooking or other purposes for which gas can be used (other than the purpose of an industrial process carried out on industrial premises)"
If you install it with the intention or 'design' of it to be used as a gas pipe, its a gas pipe.......... I've had this from HSE, I'd also call GSR and speak to the tech lads not the cust services as well
