We have a 1950's brick chimney and an inset gas fire which we have removed (local gas safe man).
I am now going to open out the builders opening to install a gas stove in the fireplace.
Our chimney is unlined but appears to draw fine from the smoke test the gas safe guy did.
Do I need to get the chimney lined if we install a gas stove. As they are glass fronted the efficiency is much higher than the old open fronted inset fire we had which some suggest means we need it lined.
We went to 2 different local suppliers.
One does mainly wood burning stoves for an inset glass fronted stove (therefore high efficiency) they quoted for lining. They weren't gas safe themselves as they sub it out.
Supplier 2 does gas and wood burners and is gas safe registered and mentioned nothing about lining the chimney. They did seem slightly less 'thorough' than the first mob though! They we're quoting in a gas stove.
Any help and advice really appreciated as want to do the right thing but not get my leg lifted in the process!
Ed
Ed
