Hello,
I've just had a 39kW Vaillant combi installed and a very good job it does too.
I want to install a range cooker in my kitchen, but am not sure if I will have enough gas pressure when the boiler is doing its thing. The boiler supply is run in 28mm copper direct from the meter. The supply to the kitchen is in half inch barrel pipe with a couple of 90 degree elbows over a 5meter run.
The incoming gas pipe is inch and a quarter.
Could I run a 20kW rated gas cooker off the existing pipework?
Thanks for guidance.
