- Joined
- 13 Mar 2017
- Messages
- 156
- Reaction score
- 15
- Country
Hi, do gas engineers do a gas tightness test when you have your boiler serviced to check for gas leaks?
Regards Dave
Regards Dave
was not done because it is not a requirement during a serviceHi Muggles, I had my gas and electric smart replaced today and upgraded. When the engineer did a tightness test on the gas it failed and he said there was a leak. I had my boiler serviced 2 weeks ago and everything was good and I wondered why this wasn't picked up on the service. I called British gas homecare cover and there engineer found the leak. I just wondered why the tightness test wasn't done on the service for safety. If I hadn't had the smart meter changed today, I wonder if the leak would have been found.
did he say how much the drop was on it ?Hi gas112, the leak was found on the compression elbow in the loft which connects the pipe to the boiler. The compression nut was loose.
I had it done a few years ago by my usual boiler engineer If I remember right he was explaining that there is an allowable drop over a certain time framedid he say how much the drop was on it ?
I was with the engineer when he found the leak, but we couldn't understand how the nut had become loose. We had to part the pipe next to it so the engineer so he could get his adjustable and grips to tighten it as it was in a tight space.did he say how much the drop was on it ?
My guess is that it was never done up in the first placeI was with the engineer when he found the leak, but we couldn't understand how the nut had become loose. We had to part the pipe next to it so the engineer so he could get his adjustable and grips to tighten it as it was in a tight space.
should be on the warning label he left youNo he didn't say.
