Gasket for downlight.
7 May 2017
Hi all,anyone know if gaskets are available for 100mm diameter led downlighters ?
Its just to reduce draughts from a very draughty loft which we have no access to,many thanks.
Depends on what you mean by “gaskets”.
Is this the seal between the ceiling surface and the light itself? Or something else?
(I Googled downlight gasket
And a number of suggestions popped up)
if the draught is coming through the fitting itself, a gasket isn’t going to fix it. you could fit THESE - they fit from underneath- but they are fiddly and need a good depth.
May be better to replace the downlights with new sealed units that are designed not to let the wind through.
