Gazebo build - what and when?
22 Jan 2021
Kent
Hi all you clever people
I am planning on building a wooden gazebo on a flat area in the garden. I'm looking to put down a brick built patio on the floor using some nice old reclaimed bricks to keep a traditional look.
My question is over the holes I dig for the verticals and the compacting of the ground (with some hardcore) prior to laying the bricks. If I dig the holes and put in the verticals first, then bring in a vibrating plate to compact all over, is this going to upset the post-holes and loosen the postmix around them? Or should I compact first and then dig and put in the verticals - but won't this make the digging of the holes that much harder?
Possibly over-thinking this but that's just me!
Thanks in advance
Consider putting in concrete spurs to avoid rot to the posts, they can be covered over with foliage and will stay secure when if put in first. If you just want wooden posts fit them first, concreted in, and cut bricks around them
Thanks for the reply. Sorry to be dim, but could you expand on what you mean by "concrete spurs"?
My uneducated guess would say you mean effectively overfilling the holes with the postmix so that the concrete sets proud of the level my brick layer will be so the post isn't in contact with any soil above the postmix? If so, how would you go about creating this spur without it just spreading out with gravity?
I have also read that putting a few inches of gravel below the post in the bottom of the hole is a good idea?
I meant a short concrete post in the ground which the posts are bolted to.
On original question though - does it matter if I do posts or wacker plate first?
These would require concrete at post location .
